"knock nuts"
  • Thread starter Thread starter jknight
  • Start date Start date
J
jknight
Guest
I'm looking to draw / call-out a stamped and tapped hole in
a sheet metal part. A manufacturer calls them a "knock nut"
but I can't find anything when searching for that term.
Is there an industry term for this?
Basically a sheet is stamped to make "volcano" shape, then
the inside of the volcano is tapped.
What do I call this? and is there standard way to draw it
or call it out in a drawing?
Thank you in advance
Hello!,
I think you have the same situation with me in topic "Forming tool with cutting" ...Is that you would like toknow also?
mm.. I don't think so. I'm looking for a couple things:
1. What is the name of this feature:
Top Right
not the clip itself, just the feature that's
stamped into the silver clip - I should be able to stamp
a
similar feature in a large sheet.
2. any design information about rules for creating them
It's not necessarily a SW-specific question... I just
know
SheetMetal guys hang out here.
EDIT: better picture
The feature, not the clip
Edited by: jknight
