key disk 1
ow16
1
need help moving rslogix key to a flash drive.
Can't do it. The activation key will not move to a removable disk drive such as your flash key, zip disk, or other another floppy disk (other than the original master disk).
If you have lost the master disk contact Rockewell for a replacement.
However, it will move to a network drive. If you do not have the master disk you can move it onto one of your network drives then onto another pc.
Hmmmm.....Have you ever MAPPED-a-NETWORK drive to your USB stick? Try it. See if it works for you.
Chris Elston
Automation & Controls Engineer
Download Sample PLC Ladder Logic Code
at MrPLC.com
"The activation key will not move to a removable disk drive such as your flash key, zip disk, or other another floppy disk (other than the original master disk)."
Not 100% sure but I recall moving activation to blank floppy, while the evmove.exe was started from the harddisk.
If you want to remove an activation code to use on another pc a way of doing it is to use norton ghost on the hard disk and take a copy of it then you can copy the full hard disk information including the activation on to another PC (as many time as you want) its not legal but possible
Mark
I have been able to successfully moved the key via CD-RW in the past.
Mapping to my USB memory stick? Who would have thunk of it?
You get a star for that one![thumbsup]
Steve
Swinney24,
Have you tried that with success? I have tried ghosting my key disk before and that didnt work. Think I might give this one a try.
Scott
In a hundred years, it isn't going to matter anyway.
Rdub,
Have you tried moving to a CD-r?
BTW, Sorry to post to twice to the same question...
Scott
ScottI2R,
I was using a laptop without a floppy drive. It was a few months ago but I'm pretty sure it was a CD-RW because it had to transfer the "fingerprint" to my laptop & clear it from the CD. I'll check and let you know for sure.
the best way is to make a few copys of your keydisk thus move them to the hard drives.
use a program called Blitz Copy,
You would be amazed at what you could do to solved these problems when software is loaded on your old windows 95 first.
Diskfactory32 will copy key disks. For backup use only!
