Joseph E. Bowles Foundation Analysis and Design 2
AaronJR
Geotechnical
TT
thread256-183631
I recently purchased the Bowles Foundation Analysis and Design 5th edition book however it did not come with the disk containing the Fortran Source code for the programs. Does anyone have a download for the fortran programs?
Joe Bowles may still be around so try to find him on the Internet and ask a Question.
You might have to contact the publisher. Are you still using Fortran? I don't know if it runs under window environment.
I found the programs using a google search, but I do find it odd you want to perform engineering in 2020 using software developed in 1996 by a company that no longer exists and has no subsequent updates and the programs probably wont be compatible with your system.
If you need source code for Fortran, you can check local engineering college and library, as they might have a disk copy of it, and the dos operating environment that required to run the program.
Some of the programs were printed in the book...
Mike McCann, PE, SE (WA, HI)
Joe Bowles died quite a long time ago.
I did use some of the software in his book and it was quite good back then.
It may be possible to run these programs on a Virtual machine with windows 95 although I never tried it.
There are plenty of options for using Fortran under Windows:
Install a Windows Fortran compiler and run from a Command Window, just like you used to.
Write a Python front end and call the Fortran code using ctypes or f2py.
Install an Excel/Python interface and call the Fortran code via Python direct from Excel.
Compile as a dll and call from Excel with VBA.
There are examples of all of the above on my blog.
Doug Jenkins
Interactive Design Services
If you got the program/source code, follow the procedure, and rewrite it (if you ever used Fortran in the past).
Can someone re-share a link to the CD files.
Have the book but not the programs for some reason
