Join two tables
  • Thread starter Thread starter amd450
  • Start date Start date
A
amd450
Guest
I want join 2 tables (endpoint with endpoint), but I dont got, there are only the option >in entity , in vertex and others, but I dont kwow which I can use.
Andre Almeida
First of all, can you add columns or rows so you have just one table? If you need two different tables then the easiest way that I can think of would be to turn on both the drawing grid and grid snap. This will allow you to move tables around and snap to points of the grid. You may need to resize the table or adjust the grid size to accomodate the table sizes.
