Java version for Jlink
  • Thread starter Thread starter iharter
  • Start date Start date
I
iharter
Guest
HI<BR closure_uid_cm7yie="9452" Pc="null">I use CreoElemts with Windows7 64Bit, WF5 Also Windows7 and M060.<BR closure_uid_cm7yie="9453" Pc="null">1 - What is the ideal version of java to use the toolkit and Jlink?<BR closure_uid_cm7yie="9454" Pc="null">2 - The idel is to use the java that comes with CreoElements/WF5 or updated version of the Internet?<BR closure_uid_cm7yie="9455" Pc="null">Thank you.
As per the PTC sugguested not lower version than the 1.4.1 and above all are the compatable to work in J-Link.
Make sure the JDK is 64Bit version dependent.
Kishore V
Make sure ur JRE version is 64 bit... I guess JDK versions will not affect much!
