atrizzy
- Mar 30, 2017
- 363
I'm analyzing an existing steel stack for power plant effluent to determine adequacy for wind loading and am running into a bit of an issue. Please see the attached sketch.
The stack was designed with 4 vertical stiffeners at 90 degrees to each other running vertically for the top 40' of the stack. There are intermediate horizontal angle stiffeners, but none exists at the lower termination of the vertical stiffeners. The stiffeners just stop, abruptly, about 40' below the top of the stack.
I'm trying to determine if there is a risk of premature local buckling in the primary shell due to bending in the stack at the point where the stiffener terminates.
I'm having a tough time wrapping my mind around this. On one hand it seems if there is stress in the stiffener, it has no path but to transition to the main body but through a localized point. On the other hand, how could the entire stiffener be under stress if it terminates and there's nowhere for it to go?
I'm thinking of providing a beefy horizontal ring stiffener at this location to mitigate any potential for this issue, so that I can be sure that the flexural capacity of the entire tube section can be utilized.
Any thoughts and insight welcome. Thanks in advance.
