IPR default instead of IPM for turning.
  • Thread starter Thread starter ckirchen
  • Start date Start date
C
ckirchen
Guest
When opening a lathe workcell, or specifically an area, grooving, or profile turning sequence, is there a way to have the FEED_UNITS paramaters set to IPR by default?
The three parameters default to IPM and it is way to easy to forget to switch one of them.
A site file can handle this for you.
Another option is to save the parameters the way you like them, and then just read them in as needed.
either way is acceptable. It just depends on your preference.
-tsl
