Inventor to 3DS Max
  • Thread starter Thread starter Amerigo
  • Start date Start date
A
Amerigo
Guest
Does any one know how to import inventor parts to 3DS max.
Thanks in advance.
Hi Amerigo,
For this to happen Inventor and Max must be on the same computer. Inventor has a plugin for 3DS max that allows Inventor files to be imported directly into Max. Start Max and under the customize menu choose plugins path and then choose the additional plugin tab and add a new path, for example c:\program files\autodesk\inventor\bin and then click use path and close Max and restart. Now under file import inventor files are available {both part files and assembly files}.
Thanks!
