Inventor drawing to Autocad drawing
  • Thread starter Thread starter ganesh_babu
  • Start date Start date
G
ganesh_babu
Guest
I couldn't able to convert Inventor drawing into Autocad drawing, i.e., if i pick a save as button on inventor drawing mode, save file type- *.dwg is not visible/available,
so please inform me, how to fix this error.
Save Copy as .sat
Inventor should allow you to do a Save Copy as a .sat (ACIS) type file. From there you can insert this file in ACAD (open ACAD first) then from the Insert pull down menu under ACIS file...place the .sat file at selected location and do a zoom extends. Check to see if ACAD will recognize the object as a solid part or assembly. This should get u started.
Steve
what version of inventor are yuou using? you can convert inventor drawings to autocad with the "save as" command... i do it almost daily
Jonny P. Johnston
Designer/Project Engineer
National Tube Form
Hello everybody
I dont know how to make gear with tooth to be an angle (Beta angle) in Autodesk Mechanical Desktop 2006.
Best regards
Valentin
