internal threading
  • Thread starter Thread starter poornapragna
  • Start date Start date
P
poornapragna
Guest
hi i'm a beginer with pro-e could anybody help me on how to
draw threads internally on part modelling?? i want the
standard one's as in m12!!!pl help me out on this
can this file help you ?
<a target="_blank" href="uploads/fabfra1967/2012-01-02_073322_part_threads-
<br / target="_blank">m12.prt.zip">2012-01-02_073322_part_threads-
m12.prt.zip</a>
@fabrizio_franceschetti@yahoo.it thanks for ur feedback but
the link u have put is not getting opened could you please
help me out with it!!!
Sorry,
i will send again the file.
If you cannot download this file, i can send it to your
e-mail address.
In any case, i will try to send the file also via PM
Let me know.
m12.zip">2012-01-03_075934_threads-m12.zip
Now, you can be able to download attached file...
<a target="_blank" href="uploads/fabfra1967/2012-01-03_081059_m12.zip" target="_blank">2012-01-
03_081059_m12.zip</a>
sir thanks a lot bit that is possible only if the material
is cut using hole option!! could it be done if the material
is cut using extrude cut or to cut threads holes which are
not standards in case of hole options??
using "hole" feature, with 1 feature i made hole (blind
or thru all), thread and notes.
Naturally you can follow different ways, reaching however
the design intent...
...like the attached example.
Holes #5 thru #8 are functionally the same as holes #1
thru #4; there are no differences making cosmetic
features.
<a target="_blank" href="uploads/fabfra1967/2012-01-04_042150_m12a.zip" target="_blank">2012-
01-04_042150_m12a.zip</a>
Bye
thanks a lot sir!!
