DoubleStud
- Jul 6, 2022
- 501
Lets say you have a wood shear wall that runs parallel with the floor joists above crawlspace. How would you transfer the load down to foundation?
1. Do you build foundation wall along this wall all the way to 2.25" below the plywood? (1.5" sole plate plus 3/4" ply)? This way the shearwall goes straight to concrete foundation.
2. Build foundation wall just 1.5" below the floor joist? What do you put in between?
3. Build continuous concrete footing and build wood shear wall on top of it in the crawlspace?
4. Other method?
I want to see what most engineers usually specify.
4. Other method?
