S
SEBNN
Guest
I have been having issues getting Jlink to work on my computer with Wildfire 3.0. I know that it is installed, however, I cannot see it in the toolbar or even to get the internal IDE to work.
So far I have:
-installed the latest Java SDK
-Changed the CLASSPATH variable to show the location of the .jar and java.exe files
-Compiled the test program, tried to run the resulting .class file
-restarted ProE, changed Java search paths in the config.pro file
I have the manual that is included with Jlink but that is not helping with this problem. Is there a sure fire way from installation on to make sure that Jlink works?
Thank you for your help, this has been causing a few headaches for me.
SEBNN
So far I have:
SEBNN
