Inserting Dynamic Block
  • Thread starter Thread starter Alarice
  • Start date Start date
A
Alarice
Guest
I've created a dynamic blocks and it seems to work fine in the drawing they were created in, but does not work in other drawings. I tried the insert command and a tool pallet insert but no luck.
Any suggestions!
Hi Alarice,
Check whether the block definitions are saved in your search path, if not make sure that they are in your search path.
