J
jblanck
Guest
Working in WF 2
In drawing mode there is an function to Insert>>Object>>
then the options are Create New or Create from File
I understand how to insert an MS Excel Table or Chart or a pdf but when I print the drawing these items aren't on the hard copy. (They show up on screen)
Also, when I sert a jpeg file I just get the text "filename.jpg" on the screen, not the image itself.
Am I missing a config option to fix this?
Should I upgrade wto WF4 to fix this?
Am I just out of luck?
