Information, when remeshing occurs
hj_1992
1
Hi everyone,
I am struggling to find information regarding the process of remeshing while executing FEA analysis... Where can I see at which increment remeshing is happening? I want to export this information, when the job is finished into a csv/txt file.
Thank you,
BR
Adaptive remeshing is based on remeshing rules (criteria) and error indicators. The latter can be written to output database and used to determine when adaptive meshing was applied. You can also check the message window available when you submit the adaptivity process.
