Impossible to create an external reference: selection in partA is forbidden since partb was designed in context <..>
  • Thread starter Thread starter shiyao
  • Start date Start date
S
shiyao
Guest
The "design in context" warning message means you are not working with the CATProduct assembly that was used when other references were created. You should open that assembly, which will put you in the correct contextual mode.
Are you working within an assembly?
Well Part B and Part A belong to different CATProduct , then it is not able to creat ref between them?
I also found the refs between other parts are useless and parts turned to be brown from green, what is wrong?
With the Parts being out of context (brown icon), you cannot create external references automatically. But you can create them manually by Copy & Paste Special with Link
Nothing is wrong - the parts have brown icons to indicate they are not opened in their contextual assembly.
You can instance these parts in other assemblies with no problems. You just cannot edit them.
You can use the Edit + Links tool to find the Contextual assembly and open it, then the parts with have green icons and you'll be able to edit them as you want.
Or, you can Copy & Paste Special the elements from one part to another
Thanks a lot , i got that . External references can only be built at the corresponding context!
MrCATIA,
How to avoid the cycle while creating the external references, and by the way ,how many years have you been with CATIA, seems like you know everything about it.
To avoid circular loops of references, I like to put all of my "master geometry" into a special model that controls all the other parts. I also like to publish these master geometries. Then I make all the references with links back to that one Master Part.
(I've been using CATIA for a long time. I saw a V6 demo one time, but haven't had the opportunity to use V6 or 3DExperience yet)
Do I need to practice this, if I'm making a product template using the document template creation in knowledgeware?
Yes. Never have circular loops, especially in a template.
Well, i have never ever seen the V6 version, it seems that the time gap between us is around 12 hours , so you are probably at east of USA
MrCATIA, is there any chance you can elaborate more on doing the master geometry into a special model? is special model means a product in design tree that have the 'geometrical set' where different parts are built referencing to that 'geometrical set' only?
