Importing DXF files and Resizing them
  • Thread starter Thread starter spedboy_23
  • Start date Start date
S
spedboy_23
Guest
I'm trying to import a logo into ProE Wildfire 2.0 as a DXF, which i can accomplish. I just open the file as a part, and it seems to work well. Does anyone know any better methods for doing that? I'm trying to import it so i can create an extrusion based on the logo.
Secondly, is there any way to resize the logo once imported to ProE? Using the method described above, they are imported much larger than the part i'm trying to put it on.
Thanks.
You could try using Edit, Scale Mdel in Part Mode
Thanks. That works well.
