Q
quasifun
Guest
I'm using ACAD 2007 LT and Solidworks2007. I need to import a DWG or DXF to aSolidworks project.
I have made a simple slab 1 inch thick and need to import an existing DWG on top of it as a second sketch. When it imports, it is way far from the center of the slab.
I think it has to do with the origins of the DWG not aligning with the origins of the Solidworks slab.
I have tried to move the DWG UCS (using Tools/Move USC) but still don't get a correct alignment.
How do I get the imported UCS (origin) to align up with the slabs UCS? The slab is centered and fully constrained around the origin.
Thanks for your help in advance.
