Import ACAD Drawings
  • Thread starter Thread starter kenjg
  • Start date Start date
K
kenjg
Guest
Hello All,
Well I'm back with more "Q",s. My question is: What is the fastest, simplest, easiest way to import an ACAD drawing into SW keeping the DIMS & Tolerances intact? I also have the drawing with a Template showing basic items, such as P/N, tolerances, drawing size, etc. Can I also import those in intact? Then I want to save it as an SW file.
Any info would be greatly appreciated.
Thanks in advance!
KenJG
Try exporting the acad drawing as DXF. Then simply drag and drop the dxf file in a drawing. You can also drag and drop a dxf onto a part and it will create a new sketch. Im not sure if this method will keep the text entities intact, but it is worth a shot.
Importing ACAD Files
Hello Carson,
Sorry for the late response. I have found the solution. Thanks for your help and I'm sure I'll be back again for more help.
Best Regards
KenJG
