Import ACAD Drawings
  • Thread starter Thread starter kenjg
  • Start date Start date
K
kenjg
Guest
Hello All,
Well I'm back with more "Q",s. My question is: What is the fastest, simplest, easiest way to import an ACAD drawing into SW keeping the DIMS & Tolerances intact? I also have the drawing with a Template showing basic items, such as P/N, tolerances, drawing size, etc. Can I also import those in intact? Then I want to save it as an SW file.
Any info would be greatly appreciated.
Thanks in advance!
KenJG
KenJG hi,
If you mean ACAD - AutoCAD file or DWG/DXF. You can import all together, but only sketch and dimension import excellent. In another part of your drawing, you have some of the problem.
Best Regards
Stanislav
