We are designing a pressure vessel that will hold salt water. Distilled water will be entering the vessel through a transfer line supplied by a facility. We are brainstorming ideas on how to dissolve the salt at a fast time. The existing design had a nozzle at the top of the vessel to dump the salt in. Then a pump would mix the salt within a recirculating loop. This caused a lot of damage to the pump. We also can't use any means of agitation. Any ideas on how to mix the salt with the water? We are thinking of slowly dumping the salt within the water transfer line that ends with an educator within the vessel. Any ideas are appreciated. Thank you!
