I tried to make a catia macro which is make holes visible and all other things are transparent.
Dialga1
TR
Anyone can try my code on catia for me?
And I can excapt any help for my code :)
Code:
Sub TransparentizeComponents()
    Dim productDocument As ProductDocument
    Set productDocument = CATIA.ActiveDocument
    If Not productDocument Is Nothing Then
        Dim product As Product
        Set product = productDocument.Product
        Dim selection As Selection
        Set selection = productDocument.Selection
        selection.Clear
        ' Delikleri işaretlemek için filtre tanımlanır
        Dim filter As String
        filter = "CATDrillingOperation"
        selection.Search "CATIAFiltersOnly=" & filter, False, False
        Dim drillingOp As DrillHole
        For Each drillingOp In selection
            Dim hole As Hole
            Set hole = drillingOp.ReferenceProduct
            If Not hole Is Nothing Then
                If hole.Type = catCounterboredHole Then
                    ' Counterbored delikler mavi renkte olacak ve şeffaf olmayacak
                    hole.Color = RGB(0, 0, 255)
                    hole.SetRenderStyle "catRealistic"
                Else
                    ' Diğer delikler sarı renkte olacak
                    hole.Color = RGB(255, 255, 0)
                End If
            End If
        Next drillingOp
        ' Diğer bileşenleri şeffaf hale getirir
        Dim productComponents As Products
        Set productComponents = product.Products
        Dim component As Product
        For Each component In productComponents
            If TypeName(component) <> "Hole" Then
                component.SetRenderStyle "catRealisticWithTransparency"
                component.Transparency = 50 ' Şeffaflık değeri (0 - 100 arasında ayarlanabilir)
            End If
        Next component
        CATIA.RefreshDisplay = True
    Else
        MsgBox "Aktif bir CATIA ürün belgesi bulunamadı!", vbExclamation
    End If
End Sub
