I need to use the "Wrap" command in an assembly
  • Thread starter Thread starter kpinks
  • Start date Start date
K
kpinks
Guest
I would like to use the wrap command in an assembly environment as an assembly feature. We basically have a generic part that will have assembly features added to them individually to make a variety of different parts. One of these features would be a laser engraving, but the Wrap function does not appear to be available once in an assembly?
Unless it has changed recently I don't believe you can do an assembly-level wrap. I would think the simplest way to do what you're after is to use configurations in the part showing the different wraps.
