phamENG
- Feb 6, 2015
- 7,659
Anyone have any neat tricks for limiting vibrations and unpleasant deflections in an I-joist floor? I have a 12" deep floor system spanning a little over 20'. It meets code for strength and minimum serviceability, but it's a wide open floor above and below with virtually nothing to damp the vibrations and I can foresee an issue. Using Forteweb a roughly equivalent Weyerhauser I joist (I spec APA performance rated I-joists for wider applicability) lands in the 'meh' category for floor performance.
I have finished space above and below and no wiggle room on floor depth. Since it meets code I know I'm 'ok' but I like to give my clients a little more than just 'ok' - otherwise they could just have the guy at the lumber yard size everything. Most of the methods I'm familiar with require dropping below the bottom of the joist, which isn't an option here. Blocking between the joists doesn't do much, but is better than nothing - maybe a continuous coil strap at the blocking on the bottom of the floor?
One of my more outlandish ideas is to cut a 4" round hole in the middle of the joist around the 1/3 points of the span (manufacturer guidance dependent) and string 2x4's through with a vertical 2x4 at each joist nailed into the flanges. Should work, but to say it's abnormal is probably an understatement.
