i have a doubt in macros of catia
  • Thread starter Thread starter Nandhakumar
  • Start date Start date
N
Nandhakumar
Guest
I encountered a problem while running the macros. what happened is:
I opened catia and from macros option, i select start recording. In part design, i am drawing a block (cube). then i stop recording and opened that macro, the same block is coming. But, if i tried the same thing for a block with rectangular or circular pattern, it shows error in running that macro. the error shown is “Set hybridShapeLineExplicit1 = hybridShapes1.Item(“X Axis”)”. can you please help me in rectifying that error, it will be useful for my project.
thank you. the full code is given below:
Language="VBSCRIPT"
Sub CATMain()
Set documents1 = CATIA.Documents
Set partDocument1 = documents1.Add("Part")
Set part1 = partDocument1.Part
Set bodies1 = part1.Bodies
Set body1 = bodies1.Item("PartBody")
Set sketches1 = body1.Sketches
Set originElements1 = part1.OriginElements
Set reference1 = originElements1.PlaneYZ
Set sketch1 = sketches1.Add(reference1)
Dim arrayOfVariantOfDouble1(8)
arrayOfVariantOfDouble1(0) = 0.000000
arrayOfVariantOfDouble1(1) = 0.000000
arrayOfVariantOfDouble1(2) = 0.000000
arrayOfVariantOfDouble1(3) = 0.000000
arrayOfVariantOfDouble1(4) = 1.000000
arrayOfVariantOfDouble1(5) = 0.000000
arrayOfVariantOfDouble1(6) = 0.000000
arrayOfVariantOfDouble1(7) = 0.000000
arrayOfVariantOfDouble1(8) = 1.000000
sketch1.SetAbsoluteAxisData arrayOfVariantOfDouble1
part1.InWorkObject = sketch1
Set factory2D1 = sketch1.OpenEdition()
Set geometricElements1 = sketch1.GeometricElements
Set axis2D1 = geometricElements1.Item("AbsoluteAxis")
Set line2D1 = axis2D1.GetItem("HDirection")
line2D1.ReportName = 1
Set line2D2 = axis2D1.GetItem("VDirection")
line2D2.ReportName = 2
Set point2D1 = factory2D1.CreatePoint(-8.844769, 69.496485)
point2D1.ReportName = 3
Set point2D2 = factory2D1.CreatePoint(20.637792, 69.496485)
point2D2.ReportName = 4
Set line2D3 = factory2D1.CreateLine(-8.844769, 69.496485, 20.637792, 69.496485)
line2D3.ReportName = 5
line2D3.StartPoint = point2D1
line2D3.EndPoint = point2D2
Set point2D3 = factory2D1.CreatePoint(20.637792, 40.855509)
point2D3.ReportName = 6
Set line2D4 = factory2D1.CreateLine(20.637792, 69.496485, 20.637792, 40.855509)
line2D4.ReportName = 7
line2D4.EndPoint = point2D2
line2D4.StartPoint = point2D3
Set point2D4 = factory2D1.CreatePoint(-8.844769, 40.855509)
point2D4.ReportName = 8
Set line2D5 = factory2D1.CreateLine(20.637792, 40.855509, -8.844769, 40.855509)
line2D5.ReportName = 9
line2D5.StartPoint = point2D3
line2D5.EndPoint = point2D4
Set line2D6 = factory2D1.CreateLine(-8.844769, 40.855509, -8.844769, 69.496485)
line2D6.ReportName = 10
line2D6.EndPoint = point2D4
line2D6.StartPoint = point2D1
Set constraints1 = sketch1.Constraints
Set reference2 = part1.CreateReferenceFromObject(line2D3)
Set reference3 = part1.CreateReferenceFromObject(line2D1)
Set constraint1 = constraints1.AddBiEltCst(catCstTypeHorizontality, reference2, reference3)
constraint1.Mode = catCstModeDrivingDimension
Set reference4 = part1.CreateReferenceFromObject(line2D5)
Set reference5 = part1.CreateReferenceFromObject(line2D1)
Set constraint2 = constraints1.AddBiEltCst(catCstTypeHorizontality, reference4, reference5)
constraint2.Mode = catCstModeDrivingDimension
Set reference6 = part1.CreateReferenceFromObject(line2D4)
Set reference7 = part1.CreateReferenceFromObject(line2D2)
Set constraint3 = constraints1.AddBiEltCst(catCstTypeVerticality, reference6, reference7)
constraint3.Mode = catCstModeDrivingDimension
Set reference8 = part1.CreateReferenceFromObject(line2D6)
Set reference9 = part1.CreateReferenceFromObject(line2D2)
Set constraint4 = constraints1.AddBiEltCst(catCstTypeVerticality, reference8, reference9)
constraint4.Mode = catCstModeDrivingDimension
sketch1.CloseEdition
part1.InWorkObject = body1
part1.Update
Set shapeFactory1 = part1.ShapeFactory
Set pad1 = shapeFactory1.AddNewPad(sketch1, 20.000000)
part1.Update
Set reference10 = part1.CreateReferenceFromName("")
Set reference11 = part1.CreateReferenceFromName("")
Set circPattern1 = shapeFactory1.AddNewCircPattern(pad1, 1, 2, 20.000000, 45.000000, 1, 1, reference10, reference11, True, 0.000000, True)
circPattern1.CircularPatternParameters = catInstancesandAngularSpacing
circPattern1.CircularPatternParameters = catCompleteCrown
Set angularRepartition1 = circPattern1.AngularRepartition
Set angle1 = angularRepartition1.AngularSpacing
angle1.Value = 180.000000
Set angularRepartition2 = circPattern1.AngularRepartition
Set intParam1 = angularRepartition2.InstancesCount
intParam1.Value = 2
intParam1.Value = 5
Set hybridBodies1 = part1.HybridBodies
Set hybridBody1 = hybridBodies1.Add()
Set hybridShapes1 = hybridBody1.HybridShapes
Set hybridShapeLineExplicit1 = hybridShapes1.Item("X Axis")
Set reference12 = part1.CreateReferenceFromObject(hybridShapeLineExplicit1)
circPattern1.SetRotationAxis reference12
part1.Update
End Sub
@Nandhakumar
Your code is telling CATIA to look for an axis called "X Axis" in order to complete the rotation feature. This axis must either already be in your part - or - your macro can create it by simply creating a line and telling the circle pattern to use that instead of "X Axis". See attached for what the script is looking for, but if your script creates a new part each time, then it's not going to find it.
@Nandhakumar
