i cant preview drawings
  • Thread starter Thread starter tinag
  • Start date Start date
T
tinag
Guest
Using Pro 2001, i cant preview drawings when selecting a file to open
.. altho i can preview drawings created on other seats of Pro...
Is there a config setting i have missed ??
TIA
TinaG
Yep, there is such config setting.
Set the config option save_drawing_picture_file to embed instead of the default no.
Open the drawing, save it again and you'll have your preview functionality.
Those other drawings that your mentioned are probably saved when this setting was active.
FDDesign.
Edited by: FDdesign
Thanx Tinag and FDdesign...
Iwasin the same difficulty, and thanks to your topic, it was solved
hi all!
iam using Proe2000i2. where can i find that config options file. i searched many times .i couldnt find. can u please help me.
how can it be done in wildfire 2 i mean how can i preview drawing?
save_drawing_picture_file embed
Also you can preview using productview express. Productview Express automatically installs after you select a model form the borwser.
Israr
bsnath said:
hi all!
In Wildfire 2.0, the config options are found under Tools, OPTIONS. It may be in the same place for 2000i2.
Edited by: robertib
Hellooooo...
Thanx FD.. ive been trying to find that for months....
TA!
Thanks FDdesign.
So simple, yet a little misleading. Looking at the name of the
parameter I thought it was about making a jpeg or something of the
drawing.
Thanks again.
robertib said:
bsnath said:
hi all!
thanx robertib.
but i couldnt find that "tool"menu itself in 2000i2 to find options.
is it not available in lower versions of proe or what? cananyone clarify this?
In 2000i2 you will find the configyou seek under "Utilities/Preferences"
, then you can add the config line.
Good Luck
Curtis
Thank You very much cfaulk.
i got that.
Your quite welcome.
. Have a great one.
Curtis
