I can make a rd to sq cone and get flat pattern? please help
  • Thread starter Thread starter cpthomp
  • Start date Start date
C
cpthomp
Guest
I have a project that the shop needs a flat pattern for a round to square cone. i have tried blends and conversions to sheetmetal but i can not unbend even after i rip it. any help would be great. i'm using pro2001
Both sections need to be created as rectangles/squares with filleted corners. The fillets on the square to be very small and the fillets on the round very large (leaving very small straight edges and appearing round).
Then blend the straight edges to each other and the small fillets to the large fillets.
Your part should unbend after ripping
thanks for the help i tried it and it worked the way we needed it to
