Huge amount of datum planes
  • Thread starter Thread starter Speling
  • Start date Start date
S
Speling
Guest
Hi
Sometime I have problem, which manifest like this
AS FA AS IAM CONCERNED ,THE BEST THING IS TO CONTROL THE PLANES OF EACH PART BY USING THE LAYERS,
OR ELSE HIDE THE UNWANTED PLANES USING RIGHT CLICK OPTION.
hello
yes that is right. Only layers in pro/e will give you the efficient you want to your design
colect any information you can find about using them right and start using them
xcad
At last
A couple of tips for using planes & layers:
- Create a new layer for datums with a config.pro option:
def_layer LAYER_DATUM_PLANE planes
This will put all new datums on the layer planes
- Also - if you use templates - put the 3 default datums onto their own layer - def_dats
This allows you to turn off all the default datums seperately from the created datums - handy!
Ed
A vast amount of datum-planes is poor modeling practice.
Use make-datum wherever possible..
Cccccc
To Dougr
Ok
