How to use "Purge"function at "xp" system?
  • Thread starter Thread starter gospel
  • Start date Start date
G
gospel
Guest
I can used purgeat NT system,but can't working at xp system.
Somebody can help me?
I have that similar problem. Are you running Pro on your local machine? or are you using a license server? If you are using a license server, you should be able to purge from the server. I have had problem purging from any local machine.
