How to use 3DLogix Configurator???
  • Thread starter Thread starter izukama
  • Start date Start date
I
izukama
Guest
i am confused by the help file on how to install the help, how to make it an icon etc....Can anyone out there please, for my sanity, give me a more direct and clear way to set up the configurator? Thanks you very much!!!
Dear izukama
Try this...
Create a mapkey to access the 3D logix configpro mentor,but instead of recording the key sequence,go for OS Tab of the mapkey recorder,simply add path to the exe file of your 3Dlogix configpro mentor.
once you've created the mapkey,you can easily assign an icon and drag it on to the toolbar,or you can even add this mapkey to any menu as a menu item.
regards
maurya
