how to unbend the veriousnal section sweep
  • Thread starter Thread starter davishal
  • Start date Start date
D
davishal
Guest
hello
i have made one object in sheet metal by veriousnal section sweep, i want that part unbended for the development.
its wall thickness is 5 mm.
davishal
What's a veriousnal section sweep ??
You need to create a cross section driven unbend. When you select unbend, cross section you have to specify a deform area. This deform area must go to the edge of the part. Pro/E does not generate deleloped length for this unbend.
jperkins
