how to unbend in sheetmetal
  • Thread starter Thread starter ssa1
  • Start date Start date
S
ssa1
Guest
hello,
i'm using creo 2 and have no idea how to unbend in sheetmetal. there's an option to unbend all. but I only want to unbend 4 walls. actually I model a carton using the sheetmetal. can help advise on the steps?
Hi, you are in the correct tool (Unbend) but you just need to make an adjustment in the dashboard while creating the Unbend feature. Edit Definition on the unbend feature (or create one from scratch) and in the dashboard, in the upper left, select the option to the right (arrow icon) which is "references selected manually". Then you can expand the References tab in the dashboard and remove surfaces you do not want to unbend.
got it. thanks
