Mar 8, 2006 #1 G Georgi&Jaro Guest I want to show length of arc, but every time it isshow me angle. How to show length of arc between two axes? Thank you!
Mar 8, 2006 Thread starter #2 S sip Guest Hi dimension>pick one end of the arc>pick other end of the arc>pick the arc>place the dimension. It will give you the choice of angle or arc length. Sip
Mar 8, 2006 Thread starter #3 M megaladon Guest while in sketch mode pick the radius or diameter dim and go to edit/convert to/perimeter or other option then when in drawing mode use show dimension tool View attachment 1937
