S
skraba
Guest
Hello!
I have a problem. I want to replace existing assembly with a shrinkwrap. Desired method of shrinkwrap creation is merged solid, not faceted surface.
When I create Shrinkwrap using Save To option, I can't replace assembly (Pro/E stating: assembly model and shrinkwrap model are not associated). If I try to replace assembly with a shrinkwrap, created using Data Sharing option (Insert/Data Sharing/Create Shrinkwrap from Other Model), I only get faceted surface shrinwrap, which is useless for DWGs.
How the heck do I create merged solid shrinkwrap using Insert / Data Sharing option? Or is there another way?
Jurij Skraba
Jurij Skraba
