Congratulations Kingston - your model looks pretty good. But I suggest you add R3mm fillets on all the internal edges to strengthen the part.
I see yellow H and V axis also, so the white line is probably a sketch. Right-click on the sketch and Delete will remove it, unless it's a parent to another feature. If it is a parent, then just Hide the sketch. Hide those 3 primary planes also.
