how to remove Locked Parameters
  • Thread starter Thread starter kirancitd
  • Start date Start date
K
kirancitd
Guest
I have some parts which i have taken from an intralink
in all these parts there are some parameters locked in intralink. which i can not modify / remove these.
Anybody know how to remove these. Reason is i save as the same part and created 100s of parts.
Kiran
They are probably relation driven. Delete the relation and the parameter will unlock enabling you to delete it.
You need to disconnect from any PDM system.
Set config.pro option: new_parameter_ui no
Now open your parts and you should be able to remove the Intralink-related parameters.
Hi looslib,
How to edit or remove windchill-related parameters.
One more question is, How to create locked parameters
without windchill or intralink?
Thanks in advance.
Rajiv.
Rajiv777 said:
Hi looslib,
Thanks in advance.
Rajiv.
You can create locked parameters in the parameter properties.
