A
aamir959
Guest
I have a welded assembly called as asm001.asm there are 2 parts in that (part001.prt and part002.prt) part002 has been welded to part001.
my requirement is the weld edge preparation feature has a parameter called as weld depth this parameter value must be always half of teh thickness of part002
how can i relate this parameters, and wat should be done if i need the same in multiple similar assembly drawings.
any help wld be appreciated.
