How to project any shape on plane
  • Thread starter Thread starter Roberto
  • Start date Start date
R
Roberto
Guest
Folks,
My issue is I want to project a shape on plane. What is this if I have any shape , so I create a plane I need project the external lines on that plane, but the lines which are normals to the created plane. Like as when we
Have you tried using projected Datum Curves?
(Insert > Datum > Curve > Proj..)
You can sketch lines, arcs, etc on a plane, then pick surfaces to project onto.
You can also define if it projects normal to the sketch or the surfaces..
