SA07
- Feb 22, 2018
- 372
Hi
We have 4 pipes of raw water coming from different sources which enter a small tank/ filter and then the overflow fall into a 1000 m3 tank. Not all pipes bring water at the same time. We have noticed that siphon occurs sometimes in an empty pipe. Is there a method to prevent this ? Is there a small device which can be installed on each pipe which can prevent this?
The pipes size varies from 200 to 400 mm. Thks
