How to make two angle the same?
  • Thread starter Thread starter zhappybird
  • Start date Start date
Z
zhappybird
Guest
Hi, I am a new bite for Pro Engineer 4.0, so how can i make two angle the same with a certain constrain? i can not find this kind of constratin.
thanks
I guess you mean in the sketcher - before you revolve/extrude.
While in sketcher find the name of the driving angle (for example sd35) edit the value of the driven angle to by writing the name of the driving angle and accept to add the relation.
There is no such constraint I'm afraid.
You could add a parameter to control both dimensions though. Otherwise you'll have to work around it using the other constraints.
In sketcher go to TOOLS>RELATIONS and type "angle1=angle2" Substitute the "angle1" and "angle2" for the angle dimensions name. Make sure you got both angle dimensions on the sketch, so you know there name. For example: sd3=sd5 and hit ok. Now the angles will be equal.
