How to make symbole like this
  • Thread starter Thread starter ASHOK CHAUHAN
  • Start date Start date
A
ASHOK CHAUHAN
Guest
Dear Friends:
I want to make a symbol of weld that the fillet triangle attach with the fillet symbol (triangle ). help me.
Regards:
Why do you want create your own symbol for fillet welding? Pro E has a built in library of weld symbols. Locate the folder in which Pro E is loaded. In that folder locate a subfolder called Symbols. Pro E has weld symbols conforming to both ANSI and ISO standards.
Hi Friend Anand;
You are telling very true but I want to put fillet triangle in fillet position ( filled fillet triangle, at the point of welding). and on slant edge if triangle arrow has to be attached. I am able to create the filled triangle but as I attach the fillet weld ISO or ANSI symbol it is attached on corner of edge not on slant side of triangle (because it is also a part of symbol, offcourse it is different). But I wantto make symbol like this in mydrawing.
Hi Ashok,
Please see the snapshot below showing weld symbols created in two different manners.
The symbol on theright is created by Show/Erase method and the other symbol is created using user defined symbols. In both the cases, the arrow head is attached to the Hypotenuse of the fillet Triangle. I am also attaching the weld symbol I have used for your reference.
2009-04-12_195427_fillet.rar
One more thing; if you are strictly following any of the International standards for creating welding drawings, there is no need to show any filled areas for showing the weld joint. Only a valid weld symbol pointing towards the weld joint is sufficient.
Anand
Edited by: anand_m_s
I can send you some symbols that are exactly what you are looking for. PM me and I will send them to you!
Phil
good
Hello Ashok,
You can create or update symbols by using Symbol gallery option,
Format -- symbol gallery.
Muthu
