how to install proe-wildfire on linux?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I lanuched the setup script, but it did not work.
I dit it on Redhat linux7.3.
I want to know if it can work on Intel based computer.
brookelee,
Did you get anykind of error when launching the script.
I have successfully installed and ran Pro/E on Redhat 8.0 and Pheobe Beta, both yeilded excelent results.
I am also having trouble installing Pro E W on Linux.
When I run the script as root with the following comand:
[root@localhost tmp]# sh /mnt/cdrom/SETUP
The script stalls with the following error:
: command not foundine 37:
/mnt/cdrom/SETUP: line 77: syntax error near unexpected token `elif'
/mnt/cdrom/SETUP: line 77: ` elif [ $1 = ? -o $1 = -h -o $1 = -help
Its trying to set the display to something...
Can somone please quide me in the right direction?
Figured it out. The problem is that I am installing it onto Mandrake Linux 9.0. The installer script could not determing what OS was running. I copied the entire install cd to the HD, then editid the getpms.chs script.
I just deleted it all and setid=i486_Linux
Works after this.
how you figured it out?
I have that same problem??---->
/mnt/cdrom/SETUP: line 77: ` elif [ $1 = ? -o $1 = -h -o $1 = -help']
thanks!!
I had the same question and got the same infomation:
and I ran the script on Redhat Linux 7.3. As I know it is the only certified Linux platform.
Alfsmith_9 said he succeeded on Mandrake Linux 9.0, really?
What is the difference between them?
Hi everyone.
Firstoff, I am using datecode 2003051 and redhat 8.0. Had the same error withthe install script that everyone else had. What I did to get it to work was take the setup and getpmt.csh from the previous version that were working and edited the setup file so it matched the current one. I could then run and install proe. More problems though. Nothing will run once installed. I first installed the flexlm manager and I couldn't start the server. Then I tried to run proewildfire and it bombed out with alot of command not found and setenv: command not found. Finally I get a syntex error. I am excited about proe on linux, however up to this point it has been tons of problems... I hope things improve quickly!!. Has anyone got 2003051 to work?? If so on what platform/version??
Thanks for any help you can provide
