How to install catia V5r16 help files
  • Thread starter Thread starter williams
  • Start date Start date
W
williams
Guest
The help files are supposed to be in the cds from which I installed catia from, but I cant find it.
I looked at the demonstration about how to install here,
http://www.practicalcatia.com/faq.html#Ive installed the %20Catia%20Help%20files,%20but%20how%20do%20I%20use%20them
,but mine seems to be different, maybe because I have a different version of catia(r16)
Anyone help me out.
Our usual release update package comes with all sorts of un-needed discs. The help files will be on 4 discs (HTML) for windows or on one pdf format disc. Load the first disc and the process should be pretty well automatic from there. Expect to spend "some" time doing this, and I've had disc errors occur 3 discs into the install, so be patient. You will probably have to define a document installation path the first time you attempt to use the help files.
