P
Patil Uday Vasant
Guest
I need to hide a part from an assembly model same as Hide functionality present in Creo UI. For this the scenario is as follow:
I have an assembly model "A.ASM" which contains two parts namely "B.PRT" and "C.PRT". I need to hide "B.PRT" part. For hiding the part I used "ProModelitemHide()" ProToolkit API. But function returns error as "PRO_TK_INVALID_TYPE".
So can you tell us what is the procedure to hide a part from an assembly or which ProToolkit API is used for hiding parts directly from top assembly?
