How to get the name of a drawing format
  • Thread starter Thread starter weblinker
  • Start date Start date
W
weblinker
Guest
Hello
is it possible to get the Format Name of a drawing with weblink. In the API I found
pfcSheetOwner GetSheetFormat (integerSheetNumber)
But anyhow this does not work. Is there another possibility to get this name?
Best Regards
Juergen
In Pro/TOOLKIT I can call ProDrawingFormatGet() which returns the name of the format. I would take another look at what a pfcSheetOwner is, may there's a name?
#include <ProDrawing.h>
ProError
ProDrawingFormatGet
ProDrawing drawing
/* (In)
The drawing
int sheet
/* (In)
The sheet number
ProName format_name
/* (Out)
The name of the drawing sheet's format
var CurFormat = CurDrawing.GetSheetFormat (1);
var CurFormatName = CurFormat.FullName;
Class pfcSheetOwner.GetSheetFormatlaedsto a pfcDrawingFormat-Object
Description
This class is a subclass of pfcModel; it describes a drawing format model.
Direct Parent Classes:
pfcModel
that's all. But there must be a FullName property which gives me the name of the format and it works
