how to find Override dimension in Pro-E 5
  • Thread starter Thread starter ashishvats
  • Start date Start date
A
ashishvats
Guest
How to find Override dimension in Pro-E 5.0.
Ashish
With the search function you can search for dimensions and
also specify a override dimension as type you want to
search for.
if you mean -- how to override a dimension and put your own in -- then use @O, but this can only be done to an added dimension not modelled.
Modelcheck can be used to identify dimensions that have been over-ridden.
