How to fillet between two surfaces?
  • Thread starter Thread starter Bahari
  • Start date Start date
B
Bahari
Guest
I want to add fillets between two surfaces, I cannot activate my dress up toolbar while in part design mode, since the fillet icon is not available.
Any suggestions.
Bahari - I'm a little confused by your terminology :confused:
If you want to add the fillet between surfaces, change the workbench to Generative Shape Design and use the surface fillet tools.
If you want to add the fillet between two faces of a solid, use the solid fillet tools in the Part Design workbench.
I hope that helps. Let me know if you need more help, and a picture always helps. :)
You won't be able to activate the dress up features in Wireframe and surface design. This toolbar is available in Generative shape design which will be in Shape design module.
Check that you have Generative Shape Design license in Start menu and active it.
If you want, you can add any toolbar in any workbench....
closed thread
This thread has been closed in an attempt to stop the numerous spam attachments that have occurred recently.
To add a CATIA-related comment to this thread, please start a new thread.
