how to debug step by step?
  • Thread starter Thread starter api303
  • Start date Start date
A
api303
Guest
I'd like to debug step by step in visual c++6.0,
please tell me to how to deel with it.
thanks a lot.
printf ...
printf ...
printf ...
i don't understand it .
please tell me in detail
thanks a lot
what do you mean!? i can't understand!
ok!
Now ,i am developing a Pro/Toolkit Application,and use vc++6.0 to compile my c source code.However,i can't track
parameter by using F9 and F10.how to debug it?
This is a very common question, and PTC has done a poor job documenting the process to debug toolkit applications.
Here are the following steps:
1. If you are building an EXE or a DLL then you must add the complier option to allow debugging.
/debug:full /debugtype:CV /PDBTYPE:CON /PDB:debuginfo.dat /PROFILE /MAP /MAPINFO:LINES /MAPINFO:EXPORTS
more information can be found about the debugging options in the c++ documentation under make files.
2. If you make a DLL:
After your toolkit project is running go to task manager and select the process labeled xstop.exe and debug this process. Then open your c++ code and place a break point at the location that you wish to start debugging.
2b. If you make an EXE
open task manager.
select your EXE with the right mouse and pick debug. Then open your c++ code and place a break point at the location that you wish to start debugging.
I hope this helps you and others.
Jonathan Cook
415 929 5297 (call me with any other questions)
good luck.
thank you .
open task manager.
a problem is:break point is not permitted to set.
why?Can you send me .mak file by e-mail?
my e-mail:peng_zhi007@sina.com
