How to cut an image into a surface?
  • Thread starter Thread starter mlportersr
  • Start date Start date
M
mlportersr
Guest
The subject line says most of what I want. I have a flat surface that I want to cut an image into - a line-art logo actually. The I want to extrude a cut into the surface a couple tenths of an inch. I have done this with text befoire and this seems like such a simple thing that there must be a way of doing it.
I saw a thread about incorporating an image into a sketch, but you can't do anything with it once it's there.
Hi, you can use from Tools/Sketch Entities the command Text for the special draw-quality text with closed profile.
From there, once you have the text sketch, it should be simple to extrude it by selecting all the letters.
Hope this helps!
Sent from my ZTE A2017U using Tapatalk
