How to create this cleat horn
  • Thread starter Thread starter Eyke
  • Start date Start date
E
Eyke
Guest
Good day:
I'd like to model this cleat horn (see http://www.eyke.org/cleat.pdf ).
I imagine you'd use a swept blend with different sections. My real dilemma is how to get the trajectory sketched.
I created this ACAD polyline ( http://www.eyke.org/cleatsweep.pdf ) thru the midpoint of the section lines. Now to get it into Pro/E's sketcher.
Then there's the double radius at the end of the horn. Maybe the ear command?
Any help is greatly appreciated.
TIA,
Eyke
To bring in the sketch. While in sketcher use Sketch>data from file you can use .dwg files. You would be better serverd to just do it in sketcher. If you know the dimensions, why wouldn't you?
Create a Swept blend. Accept the 3 points of interest for your sketch locations. Sketch each section.
To get the end rdii right create datum curves, surfaces, then merge them and create a protrusion Use Qulit.
Make sure you adjust the surface boundaries for tangency.
see image of part http://www.kinetivision.com/images/request/cleat.gif
I tried the Sketch->data from file. Pro/E complained about the file type. It seems that it wanted IGES.
AFA the dimensions, I only have the outside parameter dimesions. I created the polyline and used fit curve to get it to pass thru all the defining points.
I'll try again when I have some time.
Eyke
Oh..Jake....could you e-mail me the prt file? I'd like to take a look at it.
TIA
Eyke
Mr. jake can you send me the prt file. I want to study your prt file completley send the prt file to me ( e-mail id: satishkumar@iffco.com)
Sketch the side curves as a datum-curve and make sure there is a vertex (use divide in geom tools) at a,b, & c on both sides.
Sketch each of your section curves with the sketch plane to be thru the vertices for the approriate section.
Use boundary surface and select the section curves for the first direction and the side curves for the second direction.
This will take care of most of the geometry, the end can be done with boundary surfaces also (crve to point for 1st direction and slect the appropriate side curve for the 2nd direction).
